已解决 请问要怎么把这Node放在Xenforo网頁的背景上?懂放程式码的快进来看看
41G
118,768G
1、按我标注的箭头找到你所用当前模板的 page_container
2、在模板搜索<body 在其下面添加 如下图代码
HTML:
<canvas id="spiders"></canvas>
3、再搜索</body> 在其上面添加如下代码 保存
JavaScript:
    <script>
* TERMS OF USE - EASING EQUATIONS
* Open source under the BSD License.
* Copyright © 2001 Robert Penner
* All rights reserved.
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list of
* conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list
* of conditions and the following disclaimer in the documentation and/or other materials
* provided with the distribution.
* Neither the name of the author nor the names of contributors may be used to endorse
* or promote products derived from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
*  COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
*  EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
*  GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
*  NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
// http://paulirish.com/2011/requestanimationframe-for-smart-animating/
// http://my.opera.com/emoller/blog/2011/12/20/requestanimationframe-for-smart-er-animating
// requestAnimationFrame polyfill by Erik Möller. fixes from Paul Irish and Tino Zijdel
// MIT license
(function() {
    var lastTime = 0;
    var vendors = ['ms', 'moz', 'webkit', 'o'];
    for(var x = 0; x < vendors.length && !window.requestAnimationFrame; ++x) {
        window.requestAnimationFrame = window[vendors[x]+'RequestAnimationFrame'];
        window.cancelAnimationFrame = window[vendors[x]+'CancelAnimationFrame'] || window[vendors[x]+'CancelRequestAnimationFrame'];
    if (!window.requestAnimationFrame)
        window.requestAnimationFrame = function(callback, element) {
            var currTime = new Date().getTime();
            var timeToCall = Math.max(0, 16 - (currTime - lastTime));
            var id = window.setTimeout(function() { callback(currTime + timeToCall); },
                timeToCall);
            lastTime = currTime + timeToCall;
            return id;
    if (!window.cancelAnimationFrame)
        window.cancelAnimationFrame = function(id) {
            clearTimeout(id);
* VERSION: 1.13.1
* DATE: 2014-07-22
* UPDATES AND DOCS AT: https://www.greensock.com
* @license Copyright (c) 2008-2014, GreenSock. All rights reserved.
* This work is subject to the terms at https://www.greensock.com/terms_of_use.html or for
* Club GreenSock members, the software agreement that was issued with your membership.
* @author: Jack Doyle, jack@greensock.com
(function(t,e){"use strict";var i=t.GreenSockGlobals=t.GreenSockGlobals||t;if(!i.TweenLite){var s,n,r,a,o,l=function(t){var e,s=t.split("."),n=i;for(e=0;s.length>e;e++)n[s[e]]=n=n[s[e]]||{};return n},h=l("com.greensock"),_=1e-10,u=function(t){var e,i=[],s=t.length;for(e=0;e!==s;i.push(t[e++]));return i},f=function(){},m=function(){var t=Object.prototype.toString,e=t.call([]);return function(i){return null!=i&&(i instanceof Array||"object"==typeof i&&!!i.push&&t.call(i)===e)}}(),p={},c=function(s,n,r,a){this.sc=p[s]?p[s].sc:[],p[s]=this,this.gsClass=null,this.func=r;var o=[];this.check=function(h){for(var _,u,f,m,d=n.length,v=d;--d>-1;)(_=p[n[d]]||new c(n[d],[])).gsClass?(o[d]=_.gsClass,v--):h&&_.sc.push(this);if(0===v&&r)for(u=("com.greensock."+s).split("."),f=u.pop(),m=l(u.join("."))[f]=this.gsClass=r.apply(r,o),a&&(i[f]=m,"function"==typeof define&&define.amd?define((t.GreenSockAMDPath?t.GreenSockAMDPath+"/":"")+s.split(".").pop(),[],function(){return m}):s===e&&"undefined"!=typeof module&&module.exports&&(module.exports=m)),d=0;this.sc.length>d;d++)this.sc[d].check()},this.check(!0)},d=t._gsDefine=function(t,e,i,s){return new c(t,e,i,s)},v=h._class=function(t,e,i){return e=e||function(){},d(t,[],function(){return e},i),e};d.globals=i;var g=[0,0,1,1],T=[],y=v("easing.Ease",function(t,e,i,s){this._func=t,this._type=i||0,this._power=s||0,this._params=e?g.concat(e):g},!0),w=y.map={},P=y.register=function(t,e,i,s){for(var n,r,a,o,l=e.split(","),_=l.length,u=(i||"easeIn,easeOut,easeInOut").split(",");--_>-1;)for(r=l[_],n=s?v("easing."+r,null,!0):h.easing[r]||{},a=u.length;--a>-1;)o=u[a],w[r+"."+o]=w[o+r]=n[o]=t.getRatio?t:t[o]||new t};for(r=y.prototype,r._calcEnd=!1,r.getRatio=function(t){if(this._func)return this._params[0]=t,this._func.apply(null,this._params);var e=this._type,i=this._power,s=1===e?1-t:2===e?t:.5>t?2*t:2*(1-t);return 1===i?s*=s:2===i?s*=s*s:3===i?s*=s*s*s:4===i&&(s*=s*s*s*s),1===e?1-s:2===e?s:.5>t?s/2:1-s/2},s=["Linear","Quad","Cubic","Quart","Quint,Strong"],n=s.length;--n>-1;)r=s[n]+",Power"+n,P(new y(null,null,1,n),r,"easeOut",!0),P(new y(null,null,2,n),r,"easeIn"+(0===n?",easeNone":"")),P(new y(null,null,3,n),r,"easeInOut");w.linear=h.easing.Linear.easeIn,w.swing=h.easing.Quad.easeInOut;var b=v("events.EventDispatcher",function(t){this._listeners={},this._eventTarget=t||this});r=b.prototype,r.addEventListener=function(t,e,i,s,n){n=n||0;var r,l,h=this._listeners[t],_=0;for(null==h&&(this._listeners[t]=h=[]),l=h.length;--l>-1;)r=h[l],r.c===e&&r.s===i?h.splice(l,1):0===_&&n>r.pr&&(_=l+1);h.splice(_,0,{c:e,s:i,up:s,pr:n}),this!==a||o||a.wake()},r.removeEventListener=function(t,e){var i,s=this._listeners[t];if(s)for(i=s.length;--i>-1;)if(s[i].c===e)return s.splice(i,1),void 0},r.dispatchEvent=function(t){var e,i,s,n=this._listeners[t];if(n)for(e=n.length,i=this._eventTarget;--e>-1;)s=n[e],s.up?s.c.call(s.s||i,{type:t,target:i}):s.c.call(s.s||i)};var k=t.requestAnimationFrame,A=t.cancelAnimationFrame,S=Date.now||function(){return(new Date).getTime()},x=S();for(s=["ms","moz","webkit","o"],n=s.length;--n>-1&&!k;)k=t[s[n]+"RequestAnimationFrame"],A=t[s[n]+"CancelAnimationFrame"]||t[s[n]+"CancelRequestAnimationFrame"];v("Ticker",function(t,e){var i,s,n,r,l,h=this,u=S(),m=e!==!1&&k,p=500,c=33,d=function(t){var e,a,o=S()-x;o>p&&(u+=o-c),x+=o,h.time=(x-u)/1e3,e=h.time-l,(!i||e>0||t===!0)&&(h.frame++,l+=e+(e>=r?.004:r-e),a=!0),t!==!0&&(n=s(d)),a&&h.dispatchEvent("tick")};b.call(h),h.time=h.frame=0,h.tick=function(){d(!0)},h.lagSmoothing=function(t,e){p=t||1/_,c=Math.min(e,p,0)},h.sleep=function(){null!=n&&(m&&A?A(n):clearTimeout(n),s=f,n=null,h===a&&(o=!1))},h.wake=function(){null!==n?h.sleep():h.frame>10&&(x=S()-p+5),s=0===i?f:m&&k?k:function(t){return setTimeout(t,0|1e3*(l-h.time)+1)},h===a&&(o=!0),d(2)},h.fps=function(t){return arguments.length?(i=t,r=1/(i||60),l=this.time+r,h.wake(),void 0):i},h.useRAF=function(t){return arguments.length?(h.sleep(),m=t,h.fps(i),void 0):m},h.fps(t),setTimeout(function(){m&&(!n||5>h.frame)&&h.useRAF(!1)},1500)}),r=h.Ticker.prototype=new h.events.EventDispatcher,r.constructor=h.Ticker;var C=v("core.Animation",function(t,e){if(this.vars=e=e||{},this._duration=this._totalDuration=t||0,this._delay=Number(e.delay)||0,this._timeScale=1,this._active=e.immediateRender===!0,this.data=e.data,this._reversed=e.reversed===!0,B){o||a.wake();var i=this.vars.useFrames?q:B;i.add(this,i._time),this.vars.paused&&this.paused(!0)}});a=C.ticker=new h.Ticker,r=C.prototype,r._dirty=r._gc=r._initted=r._paused=!1,r._totalTime=r._time=0,r._rawPrevTime=-1,r._next=r._last=r._onUpdate=r._timeline=r.timeline=null,r._paused=!1;var R=function(){o&&S()-x>2e3&&a.wake(),setTimeout(R,2e3)};R(),r.play=function(t,e){return null!=t&&this.seek(t,e),this.reversed(!1).paused(!1)},r.pause=function(t,e){return null!=t&&this.seek(t,e),this.paused(!0)},r.resume=function(t,e){return null!=t&&this.seek(t,e),this.paused(!1)},r.seek=function(t,e){return this.totalTime(Number(t),e!==!1)},r.restart=function(t,e){return this.reversed(!1).paused(!1).totalTime(t?-this._delay:0,e!==!1,!0)},r.reverse=function(t,e){return null!=t&&this.seek(t||this.totalDuration(),e),this.reversed(!0).paused(!1)},r.render=function(){},r.invalidate=function(){return this},r.isActive=function(){var t,e=this._timeline,i=this._startTime;return!e||!this._gc&&!this._paused&&e.isActive()&&(t=e.rawTime())>=i&&i+this.totalDuration()/this._timeScale>t},r._enabled=function(t,e){return o||a.wake(),this._gc=!t,this._active=this.isActive(),e!==!0&&(t&&!this.timeline?this._timeline.add(this,this._startTime-this._delay):!t&&this.timeline&&this._timeline._remove(this,!0)),!1},r._kill=function(){return this._enabled(!1,!1)},r.kill=function(t,e){return this._kill(t,e),this},r._uncache=function(t){for(var e=t?this:this.timeline;e;)e._dirty=!0,e=e.timeline;return this},r._swapSelfInParams=function(t){for(var e=t.length,i=t.concat();--e>-1;)"{self}"===t[e]&&(i[e]=this);return i},r.eventCallback=function(t,e,i,s){if("on"===(t||"").substr(0,2)){var n=this.vars;if(1===arguments.length)return n[t];null==e?delete n[t]:(n[t]=e,n[t+"Params"]=m(i)&&-1!==i.join("").indexOf("{self}")?this._swapSelfInParams(i):i,n[t+"Scope"]=s),"onUpdate"===t&&(this._onUpdate=e)}return this},r.delay=function(t){return arguments.length?(this._timeline.smoothChildTiming&&this.startTime(this._startTime+t-this._delay),this._delay=t,this):this._delay},r.duration=function(t){return arguments.length?(this._duration=this._totalDuration=t,this._uncache(!0),this._timeline.smoothChildTiming&&this._time>0&&this._time<this._duration&&0!==t&&this.totalTime(this._totalTime*(t/this._duration),!0),this):(this._dirty=!1,this._duration)},r.totalDuration=function(t){return this._dirty=!1,arguments.length?this.duration(t):this._totalDuration},r.time=function(t,e){return arguments.length?(this._dirty&&this.totalDuration(),this.totalTime(t>this._duration?this._duration:t,e)):this._time},r.totalTime=function(t,e,i){if(o||a.wake(),!arguments.length)return this._totalTime;if(this._timeline){if(0>t&&!i&&(t+=this.totalDuration()),this._timeline.smoothChildTiming){this._dirty&&this.totalDuration();var s=this._totalDuration,n=this._timeline;if(t>s&&!i&&(t=s),this._startTime=(this._paused?this._pauseTime:n._time)-(this._reversed?s-t:t)/this._timeScale,n._dirty||this._uncache(!1),n._timeline)for(;n._timeline;)n._timeline._time!==(n._startTime+n._totalTime)/n._timeScale&&n.totalTime(n._totalTime,!0),n=n._timeline}this._gc&&this._enabled(!0,!1),(this._totalTime!==t||0===this._duration)&&(this.render(t,e,!1),O.length&&M())}return this},r.progress=r.totalProgress=function(t,e){return arguments.length?this.totalTime(this.duration()*t,e):this._time/this.duration()},r.startTime=function(t){return arguments.length?(t!==this._startTime&&(this._startTime=t,this.timeline&&this.timeline._sortChildren&&this.timeline.add(this,t-this._delay)),this):this._startTime},r.timeScale=function(t){if(!arguments.length)return this._timeScale;if(t=t||_,this._timeline&&this._timeline.smoothChildTiming){var e=this._pauseTime,i=e||0===e?e:this._timeline.totalTime();this._startTime=i-(i-this._startTime)*this._timeScale/t}return this._timeScale=t,this._uncache(!1)},r.reversed=function(t){return arguments.length?(t!=this._reversed&&(this._reversed=t,this.totalTime(this._timeline&&!this._timeline.smoothChildTiming?this.totalDuration()-this._totalTime:this._totalTime,!0)),this):this._reversed},r.paused=function(t){if(!arguments.length)return this._paused;if(t!=this._paused&&this._timeline){o||t||a.wake();var e=this._timeline,i=e.rawTime(),s=i-this._pauseTime;!t&&e.smoothChildTiming&&(this._startTime+=s,this._uncache(!1)),this._pauseTime=t?i:null,this._paused=t,this._active=this.isActive(),!t&&0!==s&&this._initted&&this.duration()&&this.render(e.smoothChildTiming?this._totalTime:(i-this._startTime)/this._timeScale,!0,!0)}return this._gc&&!t&&this._enabled(!0,!1),this};var D=v("core.SimpleTimeline",function(t){C.call(this,0,t),this.autoRemoveChildren=this.smoothChildTiming=!0});r=D.prototype=new C,r.constructor=D,r.kill()._gc=!1,r._first=r._last=null,r._sortChildren=!1,r.add=r.insert=function(t,e){var i,s;if(t._startTime=Number(e||0)+t._delay,t._paused&&this!==t._timeline&&(t._pauseTime=t._startTime+(this.rawTime()-t._startTime)/t._timeScale),t.timeline&&t.timeline._remove(t,!0),t.timeline=t._timeline=this,t._gc&&t._enabled(!0,!0),i=this._last,this._sortChildren)for(s=t._startTime;i&&i._startTime>s;)i=i._prev;return i?(t._next=i._next,i._next=t):(t._next=this._first,this._first=t),t._next?t._next._prev=t:this._last=t,t._prev=i,this._timeline&&this._uncache(!0),this},r._remove=function(t,e){return t.timeline===this&&(e||t._enabled(!1,!0),t._prev?t._prev._next=t._next:this._first===t&&(this._first=t._next),t._next?t._next._prev=t._prev:this._last===t&&(this._last=t._prev),t._next=t._prev=t.timeline=null,this._timeline&&this._uncache(!0)),this},r.render=function(t,e,i){var s,n=this._first;for(this._totalTime=this._time=this._rawPrevTime=t;n;)s=n._next,(n._active||t>=n._startTime&&!n._paused)&&(n._reversed?n.render((n._dirty?n.totalDuration():n._totalDuration)-(t-n._startTime)*n._timeScale,e,i):n.render((t-n._startTime)*n._timeScale,e,i)),n=s},r.rawTime=function(){return o||a.wake(),this._totalTime};var I=v("TweenLite",function(e,i,s){if(C.call(this,i,s),this.render=I.prototype.render,null==e)throw"Cannot tween a null target.";this.target=e="string"!=typeof e?e:I.selector(e)||e;var n,r,a,o=e.jquery||e.length&&e!==t&&e[0]&&(e[0]===t||e[0].nodeType&&e[0].style&&!e.nodeType),l=this.vars.overwrite;if(this._overwrite=l=null==l?Q[I.defaultOverwrite]:"number"==typeof l?l>>0:Q[l],(o||e instanceof Array||e.push&&m(e))&&"number"!=typeof e[0])for(this._targets=a=u(e),this._propLookup=[],this._siblings=[],n=0;a.length>n;n++)r=a[n],r?"string"!=typeof r?r.length&&r!==t&&r[0]&&(r[0]===t||r[0].nodeType&&r[0].style&&!r.nodeType)?(a.splice(n--,1),this._targets=a=a.concat(u(r))):(this._siblings[n]=$(r,this,!1),1===l&&this._siblings[n].length>1&&K(r,this,null,1,this._siblings[n])):(r=a[n--]=I.selector(r),"string"==typeof r&&a.splice(n+1,1)):a.splice(n--,1);else this._propLookup={},this._siblings=$(e,this,!1),1===l&&this._siblings.length>1&&K(e,this,null,1,this._siblings);(this.vars.immediateRender||0===i&&0===this._delay&&this.vars.immediateRender!==!1)&&(this._time=-_,this.render(-this._delay))},!0),E=function(e){return e.length&&e!==t&&e[0]&&(e[0]===t||e[0].nodeType&&e[0].style&&!e.nodeType)},z=function(t,e){var i,s={};for(i in t)G[i]||i in e&&"transform"!==i&&"x"!==i&&"y"!==i&&"width"!==i&&"height"!==i&&"className"!==i&&"border"!==i||!(!U[i]||U[i]&&U[i]._autoCSS)||(s[i]=t[i],delete t[i]);t.css=s};r=I.prototype=new C,r.constructor=I,r.kill()._gc=!1,r.ratio=0,r._firstPT=r._targets=r._overwrittenProps=r._startAt=null,r._notifyPluginsOfEnabled=r._lazy=!1,I.version="1.13.1",I.defaultEase=r._ease=new y(null,null,1,1),I.defaultOverwrite="auto",I.ticker=a,I.autoSleep=!0,I.lagSmoothing=function(t,e){a.lagSmoothing(t,e)},I.selector=t.$||t.jQuery||function(e){var i=t.$||t.jQuery;return i?(I.selector=i,i(e)):"undefined"==typeof document?e:document.querySelectorAll?document.querySelectorAll(e):document.getElementById("#"===e.charAt(0)?e.substr(1):e)};var O=[],L={},N=I._internals={isArray:m,isSelector:E,lazyTweens:O},U=I._plugins={},F=N.tweenLookup={},j=0,G=N.reservedProps={ease:1,delay:1,overwrite:1,onComplete:1,onCompleteParams:1,onCompleteScope:1,useFrames:1,runBackwards:1,startAt:1,onUpdate:1,onUpdateParams:1,onUpdateScope:1,onStart:1,onStartParams:1,onStartScope:1,onReverseComplete:1,onReverseCompleteParams:1,onReverseCompleteScope:1,onRepeat:1,onRepeatParams:1,onRepeatScope:1,easeParams:1,yoyo:1,immediateRender:1,repeat:1,repeatDelay:1,data:1,paused:1,reversed:1,autoCSS:1,lazy:1},Q={none:0,all:1,auto:2,concurrent:3,allOnStart:4,preexisting:5,"true":1,"false":0},q=C._rootFramesTimeline=new D,B=C._rootTimeline=new D,M=N.lazyRender=function(){var t=O.length;for(L={};--t>-1;)s=O[t],s&&s._lazy!==!1&&(s.render(s._lazy,!1,!0),s._lazy=!1);O.length=0};B._startTime=a.time,q._startTime=a.frame,B._active=q._active=!0,setTimeout(M,1),C._updateRoot=I.render=function(){var t,e,i;if(O.length&&M(),B.render((a.time-B._startTime)*B._timeScale,!1,!1),q.render((a.frame-q._startTime)*q._timeScale,!1,!1),O.length&&M(),!(a.frame%120)){for(i in F){for(e=F[i].tweens,t=e.length;--t>-1;)e[t]._gc&&e.splice(t,1);0===e.length&&delete F[i]}if(i=B._first,(!i||i._paused)&&I.autoSleep&&!q._first&&1===a._listeners.tick.length){for(;i&&i._paused;)i=i._next;i||a.sleep()}}},a.addEventListener("tick",C._updateRoot);var $=function(t,e,i){var s,n,r=t._gsTweenID;if(F[r||(t._gsTweenID=r="t"+j++)]||(F[r]={target:t,tweens:[]}),e&&(s=F[r].tweens,s[n=s.length]=e,i))for(;--n>-1;)s[n]===e&&s.splice(n,1);return F[r].tweens},K=function(t,e,i,s,n){var r,a,o,l;if(1===s||s>=4){for(l=n.length,r=0;l>r;r++)if((o=n[r])!==e)o._gc||o._enabled(!1,!1)&&(a=!0);else if(5===s)break;return a}var h,u=e._startTime+_,f=[],m=0,p=0===e._duration;for(r=n.length;--r>-1;)(o=n[r])===e||o._gc||o._paused||(o._timeline!==e._timeline?(h=h||H(e,0,p),0===H(o,h,p)&&(f[m++]=o)):u>=o._startTime&&o._startTime+o.totalDuration()/o._timeScale>u&&((p||!o._initted)&&2e-10>=u-o._startTime||(f[m++]=o)));for(r=m;--r>-1;)o=f[r],2===s&&o._kill(i,t)&&(a=!0),(2!==s||!o._firstPT&&o._initted)&&o._enabled(!1,!1)&&(a=!0);return a},H=function(t,e,i){for(var s=t._timeline,n=s._timeScale,r=t._startTime;s._timeline;){if(r+=s._startTime,n*=s._timeScale,s._paused)return-100;s=s._timeline}return r/=n,r>e?r-e:i&&r===e||!t._initted&&2*_>r-e?_:(r+=t.totalDuration()/t._timeScale/n)>e+_?0:r-e-_};r._init=function(){var t,e,i,s,n,r=this.vars,a=this._overwrittenProps,o=this._duration,l=!!r.immediateRender,h=r.ease;if(r.startAt){this._startAt&&(this._startAt.render(-1,!0),this._startAt.kill()),n={};for(s in r.startAt)n[s]=r.startAt[s];if(n.overwrite=!1,n.immediateRender=!0,n.lazy=l&&r.lazy!==!1,n.startAt=n.delay=null,this._startAt=I.to(this.target,0,n),l)if(this._time>0)this._startAt=null;else if(0!==o)return}else if(r.runBackwards&&0!==o)if(this._startAt)this._startAt.render(-1,!0),this._startAt.kill(),this._startAt=null;else{i={};for(s in r)G[s]&&"autoCSS"!==s||(i[s]=r[s]);if(i.overwrite=0,i.data="isFromStart",i.lazy=l&&r.lazy!==!1,i.immediateRender=l,this._startAt=I.to(this.target,0,i),l){if(0===this._time)return}else this._startAt._init(),this._startAt._enabled(!1)}if(this._ease=h=h?h instanceof y?h:"function"==typeof h?new y(h,r.easeParams):w[h]||I.defaultEase:I.defaultEase,r.easeParams instanceof Array&&h.config&&(this._ease=h.config.apply(h,r.easeParams)),this._easeType=this._ease._type,this._easePower=this._ease._power,this._firstPT=null,this._targets)for(t=this._targets.length;--t>-1;)this._initProps(this._targets[t],this._propLookup[t]={},this._siblings[t],a?a[t]:null)&&(e=!0);else e=this._initProps(this.target,this._propLookup,this._siblings,a);if(e&&I._onPluginEvent("_onInitAllProps",this),a&&(this._firstPT||"function"!=typeof this.target&&this._enabled(!1,!1)),r.runBackwards)for(i=this._firstPT;i;)i.s+=i.c,i.c=-i.c,i=i._next;this._onUpdate=r.onUpdate,this._initted=!0},r._initProps=function(e,i,s,n){var r,a,o,l,h,_;if(null==e)return!1;L[e._gsTweenID]&&M(),this.vars.css||e.style&&e!==t&&e.nodeType&&U.css&&this.vars.autoCSS!==!1&&z(this.vars,e);for(r in this.vars){if(_=this.vars[r],G[r])_&&(_ instanceof Array||_.push&&m(_))&&-1!==_.join("").indexOf("{self}")&&(this.vars[r]=_=this._swapSelfInParams(_,this));else if(U[r]&&(l=new U[r])._onInitTween(e,this.vars[r],this)){for(this._firstPT=h={_next:this._firstPT,t:l,p:"setRatio",s:0,c:1,f:!0,n:r,pg:!0,pr:l._priority},a=l._overwriteProps.length;--a>-1;)i[l._overwriteProps[a]]=this._firstPT;(l._priority||l._onInitAllProps)&&(o=!0),(l._onDisable||l._onEnable)&&(this._notifyPluginsOfEnabled=!0)}else this._firstPT=i[r]=h={_next:this._firstPT,t:e,p:r,f:"function"==typeof e[r],n:r,pg:!1,pr:0},h.s=h.f?e[r.indexOf("set")||"function"!=typeof e["get"+r.substr(3)]?r:"get"+r.substr(3)]():parseFloat(e[r]),h.c="string"==typeof _&&"="===_.charAt(1)?parseInt(_.charAt(0)+"1",10)*Number(_.substr(2)):Number(_)-h.s||0;h&&h._next&&(h._next._prev=h)}return n&&this._kill(n,e)?this._initProps(e,i,s,n):this._overwrite>1&&this._firstPT&&s.length>1&&K(e,this,i,this._overwrite,s)?(this._kill(i,e),this._initProps(e,i,s,n)):(this._firstPT&&(this.vars.lazy!==!1&&this._duration||this.vars.lazy&&!this._duration)&&(L[e._gsTweenID]=!0),o)},r.render=function(t,e,i){var s,n,r,a,o=this._time,l=this._duration,h=this._rawPrevTime;if(t>=l)this._totalTime=this._time=l,this.ratio=this._ease._calcEnd?this._ease.getRatio(1):1,this._reversed||(s=!0,n="onComplete"),0===l&&(this._initted||!this.vars.lazy||i)&&(this._startTime===this._timeline._duration&&(t=0),(0===t||0>h||h===_)&&h!==t&&(i=!0,h>_&&(n="onReverseComplete")),this._rawPrevTime=a=!e||t||h===t?t:_);else if(1e-7>t)this._totalTime=this._time=0,this.ratio=this._ease._calcEnd?this._ease.getRatio(0):0,(0!==o||0===l&&h>0&&h!==_)&&(n="onReverseComplete",s=this._reversed),0>t?(this._active=!1,0===l&&(this._initted||!this.vars.lazy||i)&&(h>=0&&(i=!0),this._rawPrevTime=a=!e||t||h===t?t:_)):this._initted||(i=!0);else if(this._totalTime=this._time=t,this._easeType){var u=t/l,f=this._easeType,m=this._easePower;(1===f||3===f&&u>=.5)&&(u=1-u),3===f&&(u*=2),1===m?u*=u:2===m?u*=u*u:3===m?u*=u*u*u:4===m&&(u*=u*u*u*u),this.ratio=1===f?1-u:2===f?u:.5>t/l?u/2:1-u/2}else this.ratio=this._ease.getRatio(t/l);if(this._time!==o||i){if(!this._initted){if(this._init(),!this._initted||this._gc)return;if(!i&&this._firstPT&&(this.vars.lazy!==!1&&this._duration||this.vars.lazy&&!this._duration))return this._time=this._totalTime=o,this._rawPrevTime=h,O.push(this),this._lazy=t,void 0;this._time&&!s?this.ratio=this._ease.getRatio(this._time/l):s&&this._ease._calcEnd&&(this.ratio=this._ease.getRatio(0===this._time?0:1))}for(this._lazy!==!1&&(this._lazy=!1),this._active||!this._paused&&this._time!==o&&t>=0&&(this._active=!0),0===o&&(this._startAt&&(t>=0?this._startAt.render(t,e,i):n||(n="_dummyGS")),this.vars.onStart&&(0!==this._time||0===l)&&(e||this.vars.onStart.apply(this.vars.onStartScope||this,this.vars.onStartParams||T))),r=this._firstPT;r;)r.f?r.t[r.p](r.c*this.ratio+r.s):r.t[r.p]=r.c*this.ratio+r.s,r=r._next;this._onUpdate&&(0>t&&this._startAt&&this._startTime&&this._startAt.render(t,e,i),e||(this._time!==o||s)&&this._onUpdate.apply(this.vars.onUpdateScope||this,this.vars.onUpdateParams||T)),n&&(!this._gc||i)&&(0>t&&this._startAt&&!this._onUpdate&&this._startTime&&this._startAt.render(t,e,i),s&&(this._timeline.autoRemoveChildren&&this._enabled(!1,!1),this._active=!1),!e&&this.vars[n]&&this.vars[n].apply(this.vars[n+"Scope"]||this,this.vars[n+"Params"]||T),0===l&&this._rawPrevTime===_&&a!==_&&(this._rawPrevTime=0))}},r._kill=function(t,e){if("all"===t&&(t=null),null==t&&(null==e||e===this.target))return this._lazy=!1,this._enabled(!1,!1);e="string"!=typeof e?e||this._targets||this.target:I.selector(e)||e;var i,s,n,r,a,o,l,h;if((m(e)||E(e))&&"number"!=typeof e[0])for(i=e.length;--i>-1;)this._kill(t,e[i])&&(o=!0);else{if(this._targets){for(i=this._targets.length;--i>-1;)if(e===this._targets[i]){a=this._propLookup[i]||{},this._overwrittenProps=this._overwrittenProps||[],s=this._overwrittenProps[i]=t?this._overwrittenProps[i]||{}:"all";break}}else{if(e!==this.target)return!1;a=this._propLookup,s=this._overwrittenProps=t?this._overwrittenProps||{}:"all"}if(a){l=t||a,h=t!==s&&"all"!==s&&t!==a&&("object"!=typeof t||!t._tempKill);for(n in l)(r=a[n])&&(r.pg&&r.t._kill(l)&&(o=!0),r.pg&&0!==r.t._overwriteProps.length||(r._prev?r._prev._next=r._next:r===this._firstPT&&(this._firstPT=r._next),r._next&&(r._next._prev=r._prev),r._next=r._prev=null),delete a[n]),h&&(s[n]=1);!this._firstPT&&this._initted&&this._enabled(!1,!1)}}return o},r.invalidate=function(){return this._notifyPluginsOfEnabled&&I._onPluginEvent("_onDisable",this),this._firstPT=null,this._overwrittenProps=null,this._onUpdate=null,this._startAt=null,this._initted=this._active=this._notifyPluginsOfEnabled=this._lazy=!1,this._propLookup=this._targets?{}:[],this},r._enabled=function(t,e){if(o||a.wake(),t&&this._gc){var i,s=this._targets;if(s)for(i=s.length;--i>-1;)this._siblings[i]=$(s[i],this,!0);else this._siblings=$(this.target,this,!0)}return C.prototype._enabled.call(this,t,e),this._notifyPluginsOfEnabled&&this._firstPT?I._onPluginEvent(t?"_onEnable":"_onDisable",this):!1},I.to=function(t,e,i){return new I(t,e,i)},I.from=function(t,e,i){return i.runBackwards=!0,i.immediateRender=0!=i.immediateRender,new I(t,e,i)},I.fromTo=function(t,e,i,s){return s.startAt=i,s.immediateRender=0!=s.immediateRender&&0!=i.immediateRender,new I(t,e,s)},I.delayedCall=function(t,e,i,s,n){return new I(e,0,{delay:t,onComplete:e,onCompleteParams:i,onCompleteScope:s,onReverseComplete:e,onReverseCompleteParams:i,onReverseCompleteScope:s,immediateRender:!1,useFrames:n,overwrite:0})},I.set=function(t,e){return new I(t,0,e)},I.getTweensOf=function(t,e){if(null==t)return[];t="string"!=typeof t?t:I.selector(t)||t;var i,s,n,r;if((m(t)||E(t))&&"number"!=typeof t[0]){for(i=t.length,s=[];--i>-1;)s=s.concat(I.getTweensOf(t[i],e));for(i=s.length;--i>-1;)for(r=s[i],n=i;--n>-1;)r===s[n]&&s.splice(i,1)}else for(s=$(t).concat(),i=s.length;--i>-1;)(s[i]._gc||e&&!s[i].isActive())&&s.splice(i,1);return s},I.killTweensOf=I.killDelayedCallsTo=function(t,e,i){"object"==typeof e&&(i=e,e=!1);for(var s=I.getTweensOf(t,e),n=s.length;--n>-1;)s[n]._kill(i,t)};var J=v("plugins.TweenPlugin",function(t,e){this._overwriteProps=(t||"").split(","),this._propName=this._overwriteProps[0],this._priority=e||0,this._super=J.prototype},!0);if(r=J.prototype,J.version="1.10.1",J.API=2,r._firstPT=null,r._addTween=function(t,e,i,s,n,r){var a,o;return null!=s&&(a="number"==typeof s||"="!==s.charAt(1)?Number(s)-i:parseInt(s.charAt(0)+"1",10)*Number(s.substr(2)))?(this._firstPT=o={_next:this._firstPT,t:t,p:e,s:i,c:a,f:"function"==typeof t[e],n:n||e,r:r},o._next&&(o._next._prev=o),o):void 0},r.setRatio=function(t){for(var e,i=this._firstPT,s=1e-6;i;)e=i.c*t+i.s,i.r?e=Math.round(e):s>e&&e>-s&&(e=0),i.f?i.t[i.p](e):i.t[i.p]=e,i=i._next},r._kill=function(t){var e,i=this._overwriteProps,s=this._firstPT;if(null!=t[this._propName])this._overwriteProps=[];else for(e=i.length;--e>-1;)null!=t[i[e]]&&i.splice(e,1);for(;s;)null!=t[s.n]&&(s._next&&(s._next._prev=s._prev),s._prev?(s._prev._next=s._next,s._prev=null):this._firstPT===s&&(this._firstPT=s._next)),s=s._next;return!1},r._roundProps=function(t,e){for(var i=this._firstPT;i;)(t[this._propName]||null!=i.n&&t[i.n.split(this._propName+"_").join("")])&&(i.r=e),i=i._next},I._onPluginEvent=function(t,e){var i,s,n,r,a,o=e._firstPT;if("_onInitAllProps"===t){for(;o;){for(a=o._next,s=n;s&&s.pr>o.pr;)s=s._next;(o._prev=s?s._prev:r)?o._prev._next=o:n=o,(o._next=s)?s._prev=o:r=o,o=a}o=e._firstPT=n}for(;o;)o.pg&&"function"==typeof o.t[t]&&o.t[t]()&&(i=!0),o=o._next;return i},J.activate=function(t){for(var e=t.length;--e>-1;)t[e].API===J.API&&(U[(new t[e])._propName]=t[e]);return!0},d.plugin=function(t){if(!(t&&t.propName&&t.init&&t.API))throw"illegal plugin definition.";var e,i=t.propName,s=t.priority||0,n=t.overwriteProps,r={init:"_onInitTween",set:"setRatio",kill:"_kill",round:"_roundProps",initAll:"_onInitAllProps"},a=v("plugins."+i.charAt(0).toUpperCase()+i.substr(1)+"Plugin",function(){J.call(this,i,s),this._overwriteProps=n||[]},t.global===!0),o=a.prototype=new J(i);o.constructor=a,a.API=t.API;for(e in r)"function"==typeof t[e]&&(o[r[e]]=t[e]);return a.version=t.version,J.activate([a]),a},s=t._gsQueue){for(n=0;s.length>n;n++)s[n]();for(r in p)p[r].func||t.console.log("GSAP encountered missing dependency: com.greensock."+r)}o=!1}})("undefined"!=typeof module&&module.exports&&"undefined"!=typeof global?global:this||window,"TweenLite");
$( function() {
    var width, height, canvas, ctx, points, target, animateHeader = true;
    // Main
    initHeader();
    initAnimation();
    addListeners();
    function initHeader() {
        width = window.innerWidth;
        height = window.innerHeight;
        target = {
            x: width / 2,
            y: height / 3
        canvas = document.getElementById( 'spiders' );
        canvas.width = width;
        canvas.height = height;
        ctx = canvas.getContext( '2d' );
        // create points
        points = [];
        for ( var x = 0; x < width; x = x + width / 20 ) {
            for ( var y = 0; y < height; y = y + height / 20 ) {
                var px = x + Math.random() * width / 20;
                var py = y + Math.random() * height / 20;
                var p = {
                    x: px,
                    originX: px,
                    y: py,
                    originY: py
                points.push( p );
        // for each point find the 5 closest points
        for ( var i = 0; i < points.length; i++ ) {
            var closest = [];
            var p1 = points[ i ];
            for ( var j = 0; j < points.length; j++ ) {
                var p2 = points[ j ]
                if ( !( p1 == p2 ) ) {
                    var placed = false;
                    for ( var k = 0; k < 5; k++ ) {
                        if ( !placed ) {
                            if ( closest[ k ] == undefined ) {
                                closest[ k ] = p2;
                                placed = true;
                        if ( !placed ) {
                            if ( getDistance( p1, p2 ) < getDistance( p1, closest[ k ] ) ) {
                                closest[ k ] = p2;
                                placed = true;
            p1.closest = closest;
        // assign a circle to each point
        for ( var i in points ) {
            var c = new Circle( points[ i ], 2 + Math.random() * 2, 'rgba(255,255,255,0.3)' );
            points[ i ].circle = c;
    // Event handling
    function addListeners() {
        if ( !( 'ontouchstart' in window ) ) {
            window.addEventListener( 'mousemove', mouseMove );
        window.addEventListener( 'scroll', scrollCheck );
        window.addEventListener( 'resize', resize );
    function mouseMove( e ) {
        var posx = posy = 0;
        if ( e.pageX || e.pageY ) {
            posx = e.pageX;
            posy = e.pageY;
        } else if ( e.clientX || e.clientY ) {
            posx = e.clientX + document.body.scrollLeft + document.documentElement.scrollLeft;
            posy = e.clientY + document.body.scrollTop + document.documentElement.scrollTop;
        target.x = posx;
        target.y = posy;
    function scrollCheck() {
        if ( document.body.scrollTop > height ) animateHeader = false;
        else animateHeader = true;
    function resize() {
    // animation
    function initAnimation() {
        animate();
            shiftPoint( points[ i ] );
    function animate() {
        if ( animateHeader ) {
            ctx.clearRect( 0, 0, width, height );
                // detect points in range
                if ( Math.abs( getDistance( target, points[ i ] ) ) < 2000 ) {
                    points[ i ].active = 0.2;
                    points[ i ].circle.active = 0.5;
                } else if ( Math.abs( getDistance( target, points[ i ] ) ) < 20000 ) {
                    points[ i ].active = 0.1;
                    points[ i ].circle.active = 0.3;
                } else if ( Math.abs( getDistance( target, points[ i ] ) ) < 70000 ) {
                    points[ i ].active = 0.02;
                    points[ i ].circle.active = 0.09;
                } else if ( Math.abs( getDistance( target, points[ i ] ) ) < 140000 ) {
                    points[ i ].active = 0;
                    points[ i ].circle.active = 0.02;
                } else {
                    points[ i ].circle.active = 0;
                drawLines( points[ i ] );
                points[ i ].circle.draw();
        requestAnimationFrame( animate );
    function shiftPoint( p ) {
        TweenLite.to( p, 1 + 1 * Math.random(), {
            x: p.originX - 50 + Math.random() * 100,
            y: p.originY - 50 + Math.random() * 100,
            onComplete: function() {
                shiftPoint( p );
    // Canvas manipulation
    function drawLines( p ) {
        if ( !p.active ) return;
        for ( var i in p.closest ) {
            ctx.beginPath();
            ctx.moveTo( p.x, p.y );
            ctx.lineTo( p.closest[ i ].x, p.closest[ i ].y );
            ctx.strokeStyle = 'rgba(0,0,0,' + p.active + ')';
            ctx.stroke();
    function Circle( pos, rad, color ) {
        var _this = this;
        // constructor
        ( function() {
            _this.pos = pos || null;
            _this.radius = rad || null;
            _this.color = color || null;
        this.draw = function() {
            if ( !_this.active ) return;
            ctx.beginPath();
            ctx.arc( _this.pos.x, _this.pos.y, _this.radius, 0, 2 * Math.PI, false );
            ctx.fillStyle = 'rgba(0,0,0,' + _this.active + ')';
            ctx.fill();
    // Util
    function getDistance( p1, p2 ) {
        return Math.pow( p1.x - p2.x, 2 ) + Math.pow( p1.y - p2.y, 2 );
</script>
4、返回模板列表 查找 extra.less 添加如下代码 保存 返回前台刷新页面试试效果
CSS:
canvas#spiders {
  height:100vh;
  position: absolute;
.p-pageWrapper {
background: none;
5、如需添加背景图片 extra.less 加入以下代码
CSS:
body { background:url(图片地址) center center; overflow:hidden; margin:0; padding:0; background-size:cover;}
