发表于
- 回复: 13
画像元素 提交新资源:
XenForo v1.5 Full - XenForo.v1.5对Chrome 61变化进行支持
阅读关于此资源更多信息...
阅读关于此资源更多信息...
XenForo 1.5.18 is now available for all licensed customers to download. This release fixes a number of bugs and issues that were found since the previous release. As this is a maintenance release, the vast majority of the focus was an increase in stability.
Most importantly, this release includes a fix for a security issue that was reported to us by Julien from RCE Security. The issue was not found within XF code itself, but instead a file which we previously included with XF 1.5.x within...
As promised, we are today releasing both XenForo 1.5.20 Beta 1 which implements some new functionality to aid compliance with the GDPR.
For a much more detailed overview of what GDPR is and what new features have been added, please read the following thread Upcoming changes for GDPR compliance in XF1 and...
在我们以前的以GDPR为中心的发布测试版之后,今天我们很高兴地宣布XenForo 1.5.21和XenForo 2.0.7的正式版发布,旨在解决自发布以前版本以来发现的一些问题,调整,以提高您的论坛上的GDPR合规性。
此版本中的更改摘要如下所示:
- 确保服务器端验证隐私政策/条款和规则接受表格(XF1和XF2)
- 确保数据可移植性输出中的某些字段输出已转义(XF1和XF2)
- 一些小的词组调整(XF1和XF2)
- 尝试确保新的cookie通知不会隐藏页脚链接(XF1和XF2)
- 确保数据可移植性功能仅适用于具有“管理用户”权限的管理员(XF1和XF2)
- 如果该geoLocationUrl选项为空,则不再尝试链接用户的位置(XF1和XF2)
- 如果用户的位置链接,确保noreferrer和nofollow值设置(XF1和XF2)
- 实施向管理员发送的电子邮件添加取消订阅链接(XF1)的功能
- 修复选择新的底部修补程序通知类型(XF1)的问题
- 修复无效的CSS(XF1)...
Some of the changes in XF 1.5.22 include:
- Improve compatibility with MySQL 8.0.
- Improve support for newer TLS versions in emails for PHP versions >= PHP 5.6.
- In the spam cleaner only show email addresses to admin users who have the users permission.
- Use deconstructImages on GIFs (where available) in order to reduce the resulting file size.
- Bypass username validation when renaming a user on delete.
- Ensure registration defaults do not override receive_admin_email...
此版本进行了许多更改,以提高与PHP 7.3.0的兼容性。然而,在这个时候,我们不建议在生产中使用PHP 7.3.0由于一个错误,可能会导致代码执行错误,可能导致数据丢失。我们相信这个bug将在PHP 7.3.1发布时解决。
XF 1.5.23中的一些更改包括:
以下公共模板已进行更改:
- 改善PHP 7.3的兼容性。
- 修复了不使用预期HTTP版本的cURL请求的问题。
- 记录异常时应用限制以确保不会以静默方式忽略它们。
- 删除自动完成结果中显示的头像URL中的意外HTML编码
- 删除message_user_info中的Person标记,因为有证据表明Google可能对此不满意。(XF2已采用不同的方法。)
- 在IE中,打开表情符号抽屉时禁用第一个幻灯片动画以防止渲染故障。
- 修复Safari cookie管理页面的错误链接。
- member_view
- message_user_info...
