ErrorException: [E_WARNING] Declaration of XFA\RMMarketplace\XFRM\Admin\Controller\Category::categorySaveProcess(XF\Entity\AbstractCategoryTree $category) should be compatible with XFRM\Admin\Controller\Category::categorySaveProcess(XFRM\Entity\Category $category) in src/addons/XFA/RMMarketplace/XFRM/Admin/Controller/Category.php at line 0
XF::handlePhpError() in src/vendor/composer/ClassLoader.php at line 444
include() in src/vendor/composer/ClassLoader.php at line 444
Composer\Autoload\includeFile() in src/vendor/composer/ClassLoader.php at line 322
Composer\Autoload\ClassLoader->loadClass()
spl_autoload_call()
class_exists() in src/XF/Extension.php at line 172
XF\Extension->extendClass() in src/XF/App.php at line 2661
XF\App->extendClass() in src/XF/App.php at line 1465
XF\App->XF\{closure}() in src/XF/Container.php at line 228
XF\Container->create() in src/XF/App.php at line 2616
XF\App->controller() in src/XF/Mvc/Dispatcher.php at line 276
XF\Mvc\Dispatcher->dispatchClass() in src/XF/Mvc/Dispatcher.php at line 248
XF\Mvc\Dispatcher->dispatchFromMatch() in src/XF/Mvc/Dispatcher.php at line 100
XF\Mvc\Dispatcher->dispatchLoop() in src/XF/Mvc/Dispatcher.php at line 50
XF\Mvc\Dispatcher->run() in src/XF/App.php at line 2177
XF\App->run() in src/XF.php at line 390
XF::runApp() in admin.php at line 13
RMMarketplace 是这个插件的原因,需要更新到4.1.6 目前没有拿到这个插件呢,卸载插件或者 主程序用2.0.12的。XML:ErrorException: [E_WARNING] Declaration of XFA\RMMarketplace\XFRM\Admin\Controller\Category::categorySaveProcess(XF\Entity\AbstractCategoryTree $category) should be compatible with XFRM\Admin\Controller\Category::categorySaveProcess(XFRM\Entity\Category $category) in src/addons/XFA/RMMarketplace/XFRM/Admin/Controller/Category.php at line 0 XF::handlePhpError() in src/vendor/composer/ClassLoader.php at line 444 include() in src/vendor/composer/ClassLoader.php at line 444 Composer\Autoload\includeFile() in src/vendor/composer/ClassLoader.php at line 322 Composer\Autoload\ClassLoader->loadClass() spl_autoload_call() class_exists() in src/XF/Extension.php at line 172 XF\Extension->extendClass() in src/XF/App.php at line 2661 XF\App->extendClass() in src/XF/App.php at line 1465 XF\App->XF\{closure}() in src/XF/Container.php at line 228 XF\Container->create() in src/XF/App.php at line 2616 XF\App->controller() in src/XF/Mvc/Dispatcher.php at line 276 XF\Mvc\Dispatcher->dispatchClass() in src/XF/Mvc/Dispatcher.php at line 248 XF\Mvc\Dispatcher->dispatchFromMatch() in src/XF/Mvc/Dispatcher.php at line 100 XF\Mvc\Dispatcher->dispatchLoop() in src/XF/Mvc/Dispatcher.php at line 50 XF\Mvc\Dispatcher->run() in src/XF/App.php at line 2177 XF\App->run() in src/XF.php at line 390 XF::runApp() in admin.php at line 13
资源分类调整点进去显示资源? 请问怎么解决呢?
- 防止在资源报告中双重转义资源前缀。
- 更改重写的canBookmarkContent方法的可见性以匹配父级
- 如果可用的资源类型少于两种,则阻止更改资源类型。
- 编辑资源时,如果已编辑标记,则仅尝试验证和保存标记。
- 查看资源时自动标记资源更新警报。
以下公共模板已进行更改:
必要时,应使用“过时模板”页面中的合并系统来集成这些更改。
- xfrm_resource_wrapper_macros
XFRM 2.1.4中的一些更改包括:
以下公共模板已进行更改:
- xfrm_resource_list_macros
