插件 TaigaChat Pro - Realtime chat/shoutbox(即時聊天室)
0G
_簡單來說就是聊天室,有點懶我就不翻譯了
Compatible XF Versions:
  • 1.2
  • 1.3
  • 1.4
  • 1.5
Visible Branding:
No
Description:
TaigaChat Pro brings to the table a wide array of commonly-requested features in the original TaigaChat free version , along with many improvements of my own concoction to make TaigaChat Pro more than an old-fashioned shoutbox - it is now also suited to replace highly- concurrent Flash, IRC and proprietary chatrooms.
For your money, you will not only receive a significantly more versatile and powerful product, but the same lifetime updates and support I offer on all my premium addons. By contrast, the free version of TaigaChat is largely unsupported - all future updates will be channelled into TaigaChat Pro. You are also buying into tried and tested technology - TaigaChat was one of the first major XenForo addons and has existed since the first beta versions of XenForo, with constant updates ever since.
In moving from the free version to TaigaChat Pro on my live forum, the activity of the shoutbox has drastically increased. Factors such as the new 'speed mode' refresh system and persistent message colouring have given it the 'XenForo Effect'; it is simply more fun to use. Of course, standard forum posting has not decreased - on the vast majority if not all forums, shoutbox messages and forum posts are used for entirely discrete purposes.
Message notifications in tab/window title
A new optional feature: while in the full shoutbox and the tab or window is unfocused, the title will be flashed to grab your attention when a new message is posted, akin to Facebook messenger.
Fresh installation instructions:
If upgrading from TaigaChat free, scroll down for correct instructions!
If you use [bd] Widget Framework:
  1. Upload contents of upload folder to forum root.
  2. Install new addon using addon-TaigaChat.xml.
  3. Set the permissions for all relevant user groups.
  4. Import widget_framework_taigachat_pro.xml from Appearance > Import Widgets - do NOT delete your existing widgets when prompted.
    Then, go to Appearance > List Widgets and enable one of the two available Shoutbox types (Sidebar or Full width), and additionally the 'Users in Chat ' widget if you desire.
  5. Observe the settings in Home > Options > TaigaChat Pro, especially the top setting ('Speed mode') if shoutbox security matters.
  6. If you use XenPorta and wish to include TaigaChat in your portal, upload contents of xenporta/upload folder to your forum root, then in Home > Blocks > Install Block, install TaigaChat.xml , TaigaChatAlt.xml and TaigaChatOnline.xml .
If you DO NOT use [bd] Widget Framework:
  4. For sidebar: in the forum_list template, before or after (personal preference) <xen:include template="sidebar_online_users" /> add <xen:hook name="dark_taigachat" />
    For full width above/below forum list : in the forum_list template, before or after (personal preference) <xen:if is="{$renderedNodes}"><xen:include template="node_list" /></xen:if> add <xen:hook name="dark_taigachat_alt" / >
___________________________________________________________
Free version upgrade instructions:
These instructions are only for upgrading from TaigaChat free to TaigaChat Pro, not for updating between TaigaChat Pro versions!
  1. Remove your previous template edit from the forum_list template (see old install instructions for reference).
  2. Revert all dark_taigachat* templates.
  3. Upload contents of upload folder to forum root.
  4. Upgrade the existing free addon using addon-TaigaChat.xml
  5. Set the new permissions for all relevant user groups.
  6. Import widget_framework_taigachat_pro.xml from Appearance > Import Widgets - do NOT delete your existing widgets when prompted.
  7. Observe the new settings in Home > Options > TaigaChat Pro, especially the top setting ('Speed mode') if shoutbox security matters.
  8. If you use XenPorta and wish to include TaigaChat in your portal, upload contents of xenporta/upload folder to your forum root, then in Home > Blocks > Install Block, install TaigaChatAlt.xml and TaigaChatOnline.xml . Ignore TaigaChat.xml as you already have it installed.
  1. Remove your previous template edit from the forum_list template (see old install instructions for reference). Take note of its position and type (sidebar or full width).
  4. Upgrade the existing free addon using addon-TaigaChat.xml.
  6. For sidebar: in the forum_list template, before or after (personal preference) <xen:include template="sidebar_online_users" /> add <xen:hook name="dark_taigachat" />
0G
  • 1.2
  • 1.3
  • 1.4
  • 1.5
Visible Branding:
No
Description:
Download
